2017 Berlingo pump timing DV6
Treyarnon1978
Unread post by Treyarnon1978 »
Replaced timing belt after old one stripped.
Engine repairs done looking for procedure for pump timing .
crank pin cam pin I can understand but pump wheel could be timed 180 degrees out any advice on correct procedure.
Thanks.
Peter Palmer
x 12
Re: 2017 Berlingo pump timing DV6
Unread post by Peter Palmer »
I'm no expert on this although I've done several belts on the 1.6 HDI in the past. Does it really matter if its even timed up at all, it just spins and produces high pressure fuel, its not like it injects it to different ports at different times, I would just put the pin in where it sits and try it.
however wait for more detailed answers before you blow it up or anything if I'm wrong.
