Peugeot 3008 Multifunction Display and Radio
This section is for General Enquiries or for Systems not Covered Above
Bubble
Unread post by Bubble »
Hi! I have a Peugeot 3008, 2015 Allure Exec, diesel.
The multifunction display opens and closes while driving, as if resetting itself. The radio switches off intermittently as display closes and will not come back on. The blutooth and CD player does not work when this happens. Sometimes the nav display does not work (does not display when the button is pushed). Previously, the main select/ok button was not working, but after switching the car off and on it works. Same with the radio.
Pleeaaasssseee help me!
Much appreciated
x 6956
Re: Peugeot 3008 Multifunction Display and Radio
It's the Head Unit that controls the opening and retraction of the MFD, so if the Head Unit is powering on and off, it will cause the screen to do the same.
I suggest you check the connections at the back of the Head Unit to make sure they are properly secured.
Bubble
Thank you! Will definitely take a look
