Ecu
- x 6945
Re: Ecu
Probably not, the ECUs are specific to the engine type and and the configuration. But on top of that, the Engine ECUs are matched to the BSI, so are designed not to work in any other vehicle. You would have to get a matched set (Engine ECU, BSI and Key / Fob Transponders) or get a 'virginised' engine ECU that matches the original designed for the car and programme it.
