Hi where can I get a genuine diagbox from?
Need to add and remove speed limiters on later experts and partners
Diagbox
cit-rotti
- x 77
Re: Diagbox
see article:
viewtopic.php?t=80403
- x 6945
Re: Diagbox
Diagbox is the name of the software.
You probably mean the VCI Hardware which is the interface between the vehicle's OBD port and the Laptop (and which many sellers include the patched Diagbox Software). For vehicles post 2015 you will nee d Diagbox V9.**, but beware that you will also likely need the S.1279 module for commercial vehicles that include these vans for it to communicate with.
Easydiagnostics don't have any stock now, and likely won't be selling any of these kits in future, as they will be moving to the new Bosch interface that Stellantis are gradually shifting over to as their portfolio of vehicle marques increases.
We expect to hear more news soon.
If you are sourcing one elsewhere, make sure it is a full chip kit and that you have UK support for your own benefit.
- x 1052
Re: Diagbox
.Ronney94 wrote: 09 Dec 2023, 21:47 Hi where can I get a genuine diagbox from?
Are the speed limiters factory set? If so Lexia/Diagbox may not be able to turn them off. Not 100% sure on the Expert/Partner but on the Boxer/Relay you can set the speed limiter function with Diagbox but once you set it it cant undo it again. If it is factory set you can undo it with Diagbox im afraid.
You will probably need software like ECU safe or similar.
