Citroen Dispatch 2011 1.6 diesel won’t start.
My van won’t start after not being driven for some time.
Battery is fine.
There is diesel in the tank.
Cranks but won’t fire up and run.
With a simple obd scanner I got a P0001 code.
Can anyone help?
2011 dispatch won’t start.
- x 8172
Re: 2011 dispatch won’t start.
This link will give you an understanding of the code. You will need to check your fuel pump fuses and the associated wiring and connectors. Hopefully you will find a dirty contact somewhere which will resolve the problem:
https://www.troublecodes.net/pcodes/p0001/
Hilfa
Thanks for your reply.
Is there any source which shows the locations of the fuel pump and fuel pressure control valve?
I’m struggling to find any pics or references.
Thanks again.
Thanks again.
