Hello all and thanks for any advice in advance.
2015 c4 grand Picasso 2.0 diesel 6 speed manual
I had a problem with clutch pedal going to floor
Topped with a bit of fluid work for a bit then went to floor again
I changed the clutch master cylinder and am struggling to bleed it …
I have the type with one clip onto a concentric slave cylinder
Every time you push clip in to bleed appears to let air in via clip area junction of the pipe when released rendering it impossible to bleed
Does anyone know the procedure to do this with the one clip system to get pressure back into system?
Is there another bleed point or way to do it by old ?
S
Grand Picasso mk2 2015 clutch bleeding nightmare.
Timmycitroen
