ADBLUE TANK
walter
- x 4
ADBLUE TANK
Can anyone please tell me if my Berlingo K9 2020 van as a drain plug on the adblue tank don't do a lot of miles and would like to drain it off and fill up with fresh thanks for any help.
- x 6950
Re: ADBLUE TANK
Yes they do. On the tank side that is facing toward the engine bay, there is a mount and to the right of this is the small drain cap.
Somewhere in the area circled, but don't ask me how to remove it:
- x 1061
Re: ADBLUE TANK
There is a little torx screw (T-20 from memory) holding the plug in unscrew this first then the drain plug just twists & pulls out.
Id recommend leaving the adblue filler cap on when your remove the plug as once you take the filler cap off it starts to drain out fast
