Peugeot Boxer 3.0 Problem
Cro0505
Unread post by Cro0505 »
Hallo, I have problem with boxer 3.0 2008. Problem is that battery is empty in 5 days, battery almost new 100A!
I make some diagnostic with multimeter and it take 1.20A out. On fuse 38 Interior relays is taking 0.68A and fuse 53 0.15… Someone to help why or what is on that fuse 38…or shem that I can check what is?
x 6956
Re: Peugeot Boxer 3.0 Problem
Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff. I can then check the fuse in question as these are all different vehicles with different systems depending on what engine and build you have. Also, which fuse box are you referring to for F38? On some vehicles this may be the central locking, but could be something entirely different on another one.
Cro0505
It’s Peugeot Boxer 3.0 hdi 116kw 2008 year, towing service…Can I send you privat VIN number?
x 1056
Unread post by wheeler »
Cro0505 wrote: 05 Dec 2023, 22:06 It’s Peugeot Boxer 3.0 hdi 116kw 2008 year, towing service…Can I send you privat VIN number?
The VIN will be hidden automatically if you post it here & wont be on public display.
Cro0505
x 6956
You have an outstanding after-sales campaign concerning the spare wheel winch that needs checking and possibly replacing Outstanding since 2012! I suggest you get it booked into Peugeot, Ref ZBC work will be free.
Fuses:
Passenger Compartment FuseBox passenger side (BF00)
Fuse F38 (10A): Internal relays (BSI)
Fuse F53 (7.5A): Control panel - rear fog lamps
Cro0505
Thank you very much…but what is on that fuse f38-Internal relays?
x 6956
'Internal' BSI relays mentioned are not specified.
There are 4 relays on the Passenger Cabin fusebox (BF00), but whether these are the same 'internal' BSI relays mentioned previously I can't tell you. They may be internal non-user serviceable relays.
R1 dipped beam relay
R2 heated rear screen relay
R3 1 services relay (+KK)
R4 2 services relay
Cro0505
Oke, but when I take all 4 relay out it still taking 0,68A out…mybe sheme from BSI modul, that I see how it going wiring and check that
