Parter 1.6 BlueHDi p02ed p00bc 2017
Ra101
New User
Unread post by Ra101 »
Hello i have some problem i get faulty code p00bc and p02ed and it Will show up when i drive than engine brake around 2000-3500rpm
I have Done a smoke test no leaks what i can see. :^o
Change so far
Egr valve
Maf
Reset adaptions
I have diagnostic tool so i can see live data But what should i look after?
Please have you some ideas or tips ?
Dash11
Re: Parter 1.6 BlueHDi p02ed p00bc 2017
Unread post by Dash11 »
Did you find out? Mine does the same…
x 6957
For other vehicles where both these faults are showing, there is a technical bulletin that states the EGR valve is to be replaced when both these codes are showing.
ZYHER
New User
Unread post by ZYHER »
Did anyone find solution for this?
I have 2017 208 1.6 bhdi changed everything , brand new all oem egr, throtlle body, intercooler, all sensors , hoses , chack air leaks , trry to egr off new softwere but again same problems all the time , cant find solution im pissed
Thinking to take dpf out and deactivate , what u think?
vigor975
Unread post by vigor975 »
GiveMeABreak wrote: 04 Feb 2024, 10:14 For other vehicles where both these faults are showing, there is a technical bulletin that states the EGR valve is to be replaced when both these codes are showing.
Hej,
is it possible to get this bulletin. I have the same codes showing but they are intermittent.
Igor
dma09
Unread post by dma09 »
Ra101 wrote: 04 Dec 2023, 22:26 Hello i have some problem i get faulty code p00bc and p02ed and it Will show up when i drive than engine brake around 2000-3500rpm
Change so far
Egr valve
Maf
Reset adaptions
Have the same issue on my berlingo. Did you get yours fixed ?
