DS5 power steering hose
nibssy008
Unread post by nibssy008 »
Hi good evening, I have a power steering leak and have traced it to the high and low pressure hose from rack to pump.(part no 4014SN) the leak is at the end closest to the rack. I'm wondering if anyone else has had this issue. Is it repairable or a replacement?
thanks
x 6945
Re: DS5 power steering hose
4014SN is the HIGH pressure steering pipe.
The pipes generally need replacing as the seals aren't always re-suable once they come off or have started leaking - it really depends on each case, but this one is still available.
nibssy008
I spoke to the local garage and he says both the high and low pressure hoses come as a pair. Didn't know you could buy them separately? What is the part number for the low pressure hose?
x 6945
It is a combined unit, but referred to as the HP pipe.
