Hi I have Citroen C4 Grand Picasso 2017 2.0
The trouble code it is “P2566 Turbocharger boost control position sensor- circuit intermittent” I change the solenoid valve but the fault it still remains.
C4 2017 Grand Picasso P2566
- Donor 2023
Re: C4 2017 Grand Picasso P2566
Hi, i can't say i have the solution, but I have a Peugeot Expert van 2.0 hdi. I have the same error code also including p1497.
I am told it is most likely the Turbo actuator Sensor on top of the Actuator. Mine is built into the actuator and can't be replaced, however, some are 3 screws and the sensor can be replaced individually.
It could also be an ECU Signal Error or Wiring/vacuum related problem.
