BSI training manual
Oil Can
BSI training manual
Unread post by Oil Can »
I found this Citroen manual on how the BSI works. Is there a Peugeot version available?
x 1055
Re: BSI training manual
Unread post by wheeler »
The BSI's are just the same ones used in Peugeot models. Xsara & Xsara Picasso can use different BSI's depending on age but there will be an equivalent Peugeot model that uses the same BSI.
If its for your 206 again they can be fitted with 2 main different types of BSI depending on if you have a com2000 model or not.
Oil Can
wheeler wrote: 25 Nov 2023, 16:03 The BSI's are just the same ones used in Peugeot models. Xsara & Xsara Picasso can use different BSI's depending on age but there will be an equivalent Peugeot model that uses the same BSI.
Ok thanks. The Citroen manual should give me a general idea how things work even if it's not exactly the same
