Diagbox error - not found
wazon
Unread post by wazon »
Hi.
I connected the diagbox to a Citroen car. It found the VIN, I entered the code from the door, and then these errors appeared. What am I doing wrong? What do they mean?
x 6956
Re: Diagbox error - not found
What model and year is your vehicle and what version of Diagbox are you using?
This means that whatever vehicle is connect is not recognised or the database is too old so does not have the software for your vehicle.
x 1044
Unread post by wheeler »
Going by the pictures its either a mk 1 or 2 C5 so should be fine with Lexia. On Lexia it should only really need the RP number anyway.
wazon
Citroen 2008 C5
Diagbox 9.91
x 1866
Unread post by Paul-R »
2008 could be a late Mk2 or an early Mk3.
wazon
so just try to update the database and it should work?
x 6956
So a MK I Facelift or MK II depending on how you want to define it, but DB V9.** far later than needed for this vehicle. So my next question would be what operating system are you running on the laptop that is running Diagbox? What Windows version and whether it is a 32 or 64bit version of the OS?
x 1044
Paul-R wrote: 21 Nov 2023, 10:51 2008 could be a late Mk2 or an early Mk3.
Looking at the interior door handles its a late mk2
x 1866
wheeler wrote: 21 Nov 2023, 19:48Looking at the interior door handles its a late mk2
Hercule Wheeler on the case!
