Hi all! My car is a CITROËN DS3 Hatchback 1.6 HDi 110 Diesel 112 CV / 82 kW 2009 - 2015 9HR (DV6C).
I'm getting the error p0113 via OBD scan. The main issue that i'm having is that the car display a wrong temperature (most of the time below 0) so the air that came out from the AC system is hot, even if i set the lowest temperature possible.
I've already changed the external temperature sensor located in the right mirror, and now i found out this error code.
Are the things related? I'd like to swap the faulty(?) piece with a new one like this one: https://www.auto-doc.it/topran/8209165, but i'm not sure when it is exactly located
Error P0113
- x 6945
Re: Error P0113
You need to be sure this relates to the MAP, as this fault can also relate to the mass air flow sensor (MAF). It depends on the engine and engine management system you have. We'll need your VIN to determine which is correct. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Normally for the A/C system, it does rely on the exterior temperature sensor on the wing mirror to obtain the outside ambient temperature, so if you done this already, is the vehicle temperature on the display now reading the correct temperature?
There is no mention of the MAF or MAP having any effect on the A/C system though.
leviackerman91
Re: Error P0113
I'll post the VIN later. As for the temperature, no, it's not showing a correct reading. It works fine for like 30 minutes every 3-4 days, for the rest of the time it shows a temperature between +3 and -4 even if outside it's like 20-25 degrees
- x 6945
Re: Error P0113
Then all the time you have this fault, you will also have the internal cabin temperature A/C fault. Focus on this as far as the internal heating goes. Either the sensor is a cheap version or faulty or there is a fault with the sensor wiring.
leviackerman91
Re: Error P0113
- x 6945
Re: Error P0113
That's an '8' not a 'B' but I have it now...
More importantly, you have an outstanding after sales campaign for the Airbag. You need to book in with your Citroen agent and get the work done. It will be free of charge.
| Fault Code: | P0113 |
| Description of Fault: | Measurement of the air temperature at the air flow sensor: Short circuit to positive or open circuit: Temperature too low. Voltage higher than 4,9 V for 1 seconds. |
| Conditions for Fault to clear: | Driving for 5 minutes |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
leviackerman91
Re: Error P0113
My mechanic cleared some errors, seems all fine now.
Hope it keeps like this
