Oil leak from crankshaft
Azzer1
New User
Unread post by Azzer1 »
Hello I have a Peugeot 207 it’s using over 1 litre of oil every 2-3 weeks and there is some leaking from the crankshaft. It’s a 1.6 Petrol Timing Chain
Is it a simple case slacking the aux belt, undoing the crank shaft pulley and replacing the seal? Has anyone else done it and there is 2 seals, 1 transmission end and 1 timing end I’m assuming it’s the timing end 1? Any help thanks
Huskyxantia
x 918
Re: Oil leak from crankshaft
Unread post by Huskyxantia »
Not sure if this will help ?
:-D
