Been referred here by the Peugeot forums, so saying hi and to explain my situation I’m seeing if there’s anyone closer to myself (live in Bridgend) that could help with a diagnostic
Will give more details when requested as not sure if it’s allowed in this section of the forum
TIA
Diagnostic
- x 6947
Re: Diagnostic
Have a look at our list of members who have offered Lexia / Peugeot Planet 2000 / Diagbox Diagnostics help if you haven't already seen it - link below:
At the end of the list is a link to a Google Map, showing the geographic locations of members and details. Just use the Private Message or Email links on the member's profile to contact anyone suitable.
List of Lexia / Diagbox Owners with Kits Offering Help
Bear in mind, although we update the list as often as we can, not all members are active on the Forum all the time, so it may take a while for a reply.
e20082020
Re: Diagnostic
Hi, I have a 2020 e2008 GT. I would like to change the middle button on the keyfob to pop the trunk rather than activate the headlights. Apparently there is an option to do this and also choose long or short press of the button. Please can anyone with the software confirm this before I invest. Thanks.
- x 6947
Re: Diagnostic
Functionality will depend on version - so that's not something we can determine. In any case, there's only selective opening of the boot - as in it will unlock and open very slightly, but it will not open fully as that requires motorise tailgate struts which are not an option on this vehicle.
e20082020
Re: Diagnostic
Thanks, I have installed some aftermarket electric struts. Everything works fine, but as there is no boot pop button the key I cant open it from the key. The installer option also allows to press the unlock button on the remote three times and this triggers the electric tailgate. However, the unlock signal wire is only triggered once when the remote is pressed so multiple unlock signal are not received. I am trying to install Diagbox to see if there is something I can do myself.
pablo95
- x 7
Re: Diagnostic
Hello, did you solve it? i want to do the same on C4
