I've found this link about plip programming
http://www.google.co.uk/search?q=cache: ... ming&hl=en
Hope this helps, looks like its not a case of having to go to a dealer, although I've yet to try it, first I need a plip!
Plip programming RF
h3rjp
I got it to work, do not click the link and copy from the start of http://www.google.co.uk... to the end, then paste that as the address. I've tried relinking it, but it doesn't seem to want to know.
Rob
Rob
markallinson
The above line is the complete address, it should work as I copied it from the address bar, copy it and paste it. Hope it works!
Homer
- x 16
It looks like you are trying to link to a cached Google page.
And I don't think the forum code likes the URL.
You need.....
OK, after numerous tries that seems to work, copy and paste the above line into your browser window (tip: quickly click it 3 times to select the whole thing[;)]). Apologies to anyone who's screen isn't wide enough to fit the whole line in and now has to scroll from side to side to read this page.
You need.....
Code: Select all
http://w<b></b>ww.google.co.uk/search?q=cache:7VBViWJFD-MJ:ww<b></b>w.advanced-diagnostics.com.au/keyfob.pdf+peugeot+plip+programming&hl=en
astraa
KEY FOB PROGRAMMING
CITROEN
XSARA—XANTIA—SYNERGIE– EVASION
CENTRAL DOOR LOCK (1 BUTTON PLIP KEY)
Procedure
1.
Ensure all doors are unlocked using the key.
2.
Press and hold plip key button until LED stops flashing.
3.
After releasing button, LED will light constantly.
4.
Press the Plip Button once, and LED will extinguish.
5.
Open the door and hold the Plip key near the Ignition switch, and
press the plip button one time.
6.
Now turn the ignition ON, and wait 10 seconds then turn ignition
OFF.
7.
After 5 seconds, Plip should now operate.
CENTRAL DOOR LOCK with DEADLOCKING (2 BUTTON PLIP KEY)
Procedure
1.
2.
Press and HOLD the large plip key button while the LED flashes con-
tinuously for 20 seconds. After 20 seconds press the small deadlock but-
ton once while still holding the large button.
3.
The LED will stop flashing.
4.
Release the large button and the LED will light constantly.
5.
Press the large button one time, and the LED will go out.
6.
press the large plip button one time.
7.
OFF.
8.
CITROEN
Procedure
1.
2.
3.
4.
5.
6.
OFF.
7.
Procedure
1.
2.
3.
4.
5.
6.
7.
OFF.
8.
Stuart McB
damienthorn
Try
www.peugeotdiesel.com
for programming instructions. They have them for Peugeots and are probably similar to Citroen.
Gregg1100
- x 5
<font color="blue"><font size="2"><font face="Comic Sans MS">Hi,
<b>On a 93 to 97 Xantia with 2 button plip</b>.
I sorted my flip out like this. Put your key into igition switch and turn on. Put plip right up to red dome in roof lining, by int. mirror. Press until your hear/feel a click , up to 12 times. Switch off ignition, and aim plip at dome, click it and it should work, ie lock/unlock doors. It works for me everytime. Obviously batteries should be ok in plip. If it doesn`t work, just turn ignition switch to the accessories position and retry the clicking at dome.
Hope this helps
Greg</font id="Comic Sans MS"></font id="size2"></font id="blue">
Hope this helps
- x 1238
