Sony CDXR3300 / Autoleads / Mk2 Xantia
user_3150
- New User
Hi everyone, have just fitted new cd player in my Mk2 Xantia but the steering control doesn't work with the PC9-109 lead. Should it just plug in and work or have I got to do anything else. Cheer's Alec.....
philhoward
user_3150
- New User
BALLS knowing my luck it's one of the few that don't work. I have tried a search but nothing really solid on my problem (I may not be looking hard enough). I will try e-mailing Autoleads to see what they say. There is another plug that is now redundant but I thought it was to do with the Traffic Master or the dashboard dimmer could this the steering control if so then it won't work as it doesn't match anything on the Autolead.
Stuart McB
When fitting an after market stereo and using an adaptor for the steering controls there should be a small jack plug that fits the rear of the new stereo. This tells the stereo that you have steering controls and the stereo unit then interprits the signal from the adaptor thats fitted in line. With out plugiing in this small lead (blue in colour) it won't work. Also make sure you have the adaptor plugs fitted the wright way around and in the wright order. I found on a Sony unit with a steering adaptor all worked well except the little lights on the steering controls went off when a CD was put on.
user_3150
- New User
user_3150
- New User
Stuart McB
So let me get this right. You now have a plug that is not being used? I can only go by my experience but you should have just plugged in the adaptor in line and then but the remaining small jack plug in the head unit. Or am I reading this wrong? Your old unit should of had only 2 plugs one was the speakers set up right, left, front, rear the other should be the power (on,off),permanent live (memeroy)and steering controls. Had a look at the Auto leads site and it seems to just plug in line with the small jack plug. If all fails give them a call or E-mail. [:D]
Stuart McB
philhoward
There are 3 plugs on the Autoleads; one female for the steering wheel controls (10 way), one female (power) and one male (power), both 16 way.
The speaker one and the original power one (the 2 8-way ones) plug into the 16-way female; the corresponding male then plugs into the back of your stereo.
The other 10 way connector plugs into the Autoleads; don't make the orange/black link and plug the jack plug into the back of the Stereo.
3 plugs from the car into 2 for your stereo; does this help?
Xfactor1012003
user_3150
- New User
Sorry Guys have only just got back to my p.c. This is what I have got. The original Sony lead - Plugging into the Autolead (2 X 8way)- Then the Citroen Loom ( 2 X 8 Way ) And the jack plug in the Headunit. I have a Redundant 10 Way plug on the Autolead and a Redundant Plug on the Citroen Loom. They are Redundant because they Don't fit together. This is what I am assuming to be the steering control plug. The redundant 10 Way plug has 3 wires going to the little black box and 3 going to the Power supply 8 way plug on the Auto lead if this helps.
user_3150
- New User
user_3150
- New User
