Citronics
reffro
tomsheppard
xantiav6
- x 3
tomsheppard
bernie
tomsheppard
tomsheppard
bernie
Yes Tom, I started 3 years ago!
I was going to fit a/c to my BX GTI from my brothers old GTI a/c, but I found his condensor was rotten and the evapourater had a big hole[:(!].
I've since stripped the a/c system from a 16v ( the brakes and seats already fitted to my TZD Turbo) to fit in the TD.
I fitted the sump last year before my turbo wastegate stuck open and replace it with a s/h unit from a Rover 218td.
I've just fitted the evap. to my heater unit.
I bet you had the holes already cut in the bulkhead for the 2 heater inlets and the a/c pipes in your estate?
My 2 estates have them already cut but my TZD saloon did not so I've been cutting and grinding.
At present I've got no dash and the speedo head is taped to the steering column so I can fit the wiring fom the 16v and keep useing it[^][^].
tomsheppard
