Frenzied ticking at right knee.
Panjandrum
Unread post by Panjandrum »
This happens randomly, and in short bursts. Seems to be coming from the fuse/ indicator relay area under the dash. No evidence of anything happening anywhere. Thought it was the indicator relay going mental so I replaced it. No change. Typically happens when sitting quietly at the lights.
Gerry
ItDontGo
Unread post by ItDontGo »
I have seen this problem lots on AXs and Peugeot 106s - it might be the same as on yours. Its the indicator switch. The flasher unit operates on a different switch to the supply to the lights and sometimes this switch closes when the lever is not quite centred. If you mess around with the indicator lever you may find that the noise stops. If so thats the porblem.
monkeyman
Unread post by monkeyman »
It was the indicator switch on my xantia. It was intermittant too and annoying! A slight pull on the switch would make it stop.
Stempy
Unread post by Stempy »
ditto
xantiav6
x 3
Unread post by xantiav6 »
I am describing here what I learned with this problem in a 1995 Xantia, probably it is similar on your car.
Although triggered by leakage on the indicator switch contacts, the flasher unit itself has a design fault that makes the problem much more likely to occur.
If you analyse the circuit inside the flasher box, you will see that the component values do not match those recommended by the manufacturer of the ASIC at the heart of the unit. This makes the flasher unit much more sensitive to switch leakage than it should be.
You may find that an after-market flasher unit will not have this problem.
I fixed it by opening up the flasher unit and solderfing in an extra resistor to restore the design to the correct values.
derekjl57
Unread post by derekjl57 »
Sounds exactly like the problem my colleague has with his Pug 406 (T-reg). As we have plenty of soldering irons here at work, could you post details of the modification you did, and we'll give it a go here as well.
Thanks.
xantiav6
x 3
The data sheet for the ASIC can be found at:
http://www.atmel.com/dyn/resources/prod ... oc4727.pdf
The component that sets the sensitivity to switch leakage is R2, which is physically mounted under the relay coil.
On the notes I made when I inspected the flasher from my previous car, the value fitted was 100 ohms, rather than the 1.5..2.2k ohms recommended.
I just opened up the flasher on my current car, and the component fitted for R2 is 1k ohms, just a little low.
According to the data sheet, with the correct resistor fitted, the flasher should stay silent with a leakage of up to 5k ohms.
I think on my previous car I fitted a 2.2k resistor for R2, and never had the problem until I sold the car.
regards,
Mike
cheesesliceking
Unread post by cheesesliceking »
did the exact same thing on my AX.. it was the indicator stalk.[:0]
