Ax brake discs
Xantia
Ax brake discs
Unread post by Xantia »
I am changing the front brake discs on my sons Ax 1.0 and I have a unused set of Ax GT ones(10mm thick).I know that they are identical apart from the thickness,so can anybody give a valid reason not to use them.I have fitted one tonight and will do the other side tomorrow.
Regards
Jon
Unread post by Jon »
Can't see why not.
The AX GT (13" wheels version)uses the same calipers and pads (ATE system) as your AX10.
Jon Wood
IT Supervisor
GSF t/as Andyspares
