The rev counter on my 16v has packed up, Can anyone tell me where It measures the rpm from.is it the ecu or is there maybe a speed sensor on the flywheel.
Taking the instrument pod out of the dash is a real pain,which is where I was planning to start tracing the fault.
Thanks Steve
BX16V TACHO
JohnD
- x 72
Dave1
- x 3
Hi Steve,
Nice to hear you have a 16v. I have one also but do not drive it a lot just now.
I believe the reading comes from the electronic ignition which does have a sensor on the flywheel. I think it is located just below the hp pump. However, if your car is running you would assume that the sensor is not at fault. No doubt you will get a more concrete reply shortly.
Dave
Dave
