Engine Temp Sensors
philhoward
Engine Temp Sensors
Unread post by philhoward »
I'm after the water and air temp sensors for my BX (not that it's ill; just need the sensors for something else):
Air Temp Cit 95640497
Water Temp Cit 91040370 or 91414549 (What's the difference anyway).
Are they only a dealer part as the online GSF doesn't list them.
Rob Marshall
Unread post by Rob Marshall »
isn't the water temp sensor one for the guage & one for the light????
Is the air temp sensor for the engine, or do you ahve an air temp guage?
philhoward
It's running Bosch Motronic MP3.1 (no air flow meter); i'm on about the Injection/Ignition sensors, not the gauge ones.
DLM
Unread post by DLM »
If they're the Bosch parts then I'm pretty sure there are sources of supply other than Citroen: I'm sure that variants of early Bosch fuel injection systems are found on many cars of the same period.
