hi to all.
just a quick one.
if you had breaks that had gone metal to metal and had badly gouged the front discs, would you replace the discs.
I ask this as i would every time but a friend took her car to a main dealer and was told that the discs were fine, so they just replaced the pads.
any thoughts welcome
front discs
philhoward
Kowalski
alan s
- RIP 2010
- x 6
Stuart McB
Had this with a main Ford Dealer on a 2year old Focus (ex hire) I said the disc's were worn they said that they were fine. Ended up putting a micrometer on them at home in the garage. Guess what? when faced with actual measurements they complied and the disc's were 2.5mm under the min thickness allowed. Much pulling of fore locks by the dealer.
jeremy
I've just replaced the discs on our ZX 1.9 D. I changed the pads when we got the car and thought the discs were marginal and at about £9 + VAT wished I'd done the discs as well. the brakes never felt convincing and last month I finally got round to doing them. I took the old ones off and began to wonder what I'd found wrong in the first place but having got the bits and new pads I carried on. tremendous improvement much to my surprise.
The old ones really aren't that bad. What I do wonder about is that the pads i fitted to the old discs may have been slightly larger than their predecessors ad there has obviously been contact between the pad and a rusty part of the disc (outside the shiny zone)
Curiously when I fitted 4 new discs and pads to my BX I noticed no improvement at all. Those ones were really worn!
I sugegst that you fit new ones if there is any doubt.
jeremy
jeremy
John F
The ventilated front discs on my '99 HDi Xantia have pockets cast into the outer edge which I am given to understand are there so that this generates a noise from the pads as a warning when the discs get worn to a minimum tolerance thickness. I always remove the outer "shoulder" left on the disc by the pad with a quick turning job in the lathe.
edd001
Rob Marshall
