Hi, first post here. Just gone diesel and now have a Peugeot 1996 205 1.7D 3 Door and a Citroen ZX Reflex Estate 1.9D instead of two Volvo 740's that drank petrol. I'm resizeing [:D]
As per the subject, how easy is it to fit a rev counter to the Peugeot. The ZX has one, the 205 doesn't and I do like to drive from the tach not the speedo. I don't mind aftermarket if that is easier than a new instrument panel.
Thanks in advance for any help.
Stuart
Rev counter for 205D
philhoward
The diesel tacho's (205 IIRC; the ZX definately) are fed from a sensor which looks at the flywheel; whether or not the 205 will have either the hole for the sensor, or the cutouts on the flywheel for the sensor to look at is a bit of a guess... Being a '96, then there probably is; you'd probably need something like a DTurbo instrument pack to interpret it, though.
Basil Zaharoff
Re: Rev counter for 205D
http://www.frenchcarforum.co.uk/forum/v ... =4&t=48341" onclick="window.open(this.href);return false;
