AX dash lights feed?
tfurness
Unread post by tfurness »
[black][blue]Hi my girlfriends AX dash lights don't work at all. Have replaced the bulbs but it's no better. There doesn't appear to be a feed to the "circuit" board. The radio and fog lights illumination works as it should but no dash lights. Incidentally the heater control lights don't work either but that doesn't really matter. What could be causing it? where are the earth points? Which relay is it?
Help[:(] ! -Tom
philhoward
Unread post by philhoward »
Tried the rheostat (dimmer)? Don't know about AX's inparticluar, but they tend to be on the underside of the steering column. Try wiggling it, or even shorting it out.
cheesesliceking
Unread post by cheesesliceking »
they only dim not turn off totally, fuse perhaps?
uhn113x
x 3
Unread post by uhn113x »
If the rheostat is o/c or disconnected, the dash lights will go out, despite the fact it only dims
