I need to order a new replacement BSM fuse box for a C3 Picasso 1.6 HDi (2009).
The part number for the BSM currently installed is: 9664997880 R09 BSM-00
But on the sticker I can also see some letters/digits beneath that part number.
HW7-SW7-MK8-2009-10-19-2-570
or
HW7-SW7-MK6-2009-10-19-2-570
Kinda hard to see but, do these letters need to be identical to the new BSM or is the part number only what is important?
C3 Picasso picking the right BSM replacement
- x 6945
Re: C3 Picasso picking the right BSM replacement
Those are Hardware and Software versions of the unit at factory.
As long as you have the correct 96* number you will be fine.
oppsig
Ok, thanks a lot for your help and quick reply.
oppsig
Forgot to ask, are these BSM plug and play or do they need to be programmed?
- x 6945
The engine Fuse Box on this model does not need configuring.
