My Relay has failed its MOT because the horn isn't working.and the airbag warning light is stuck on.
Horn hasn't worked for a while and the airbag light came on just before the MOT test.(!)
I have done the following checks:
Checked horn relay - OK.
Removed airbag and horn assembly and there is no power to the horn connector.
Horn switch is working.
Is this deffinately a clock spring problem or is there an easier (cheaper) solution that I've overlooked??
Has anyone got a clock spring number 07354300930 for sale?
Any help greatly appreciated.
