B132F 81
Israel2407
New User
B132F 81
Unread post by Israel2407 »
Saludos amigos, tengo un Peugeot 2008 año 2020 que tiene problema con el aire acondicionado, al encender enfría, luego se elevan las presiones y apaga el compresor, me arroja el código B132F 81, ya se cambió todo el sistema de aire acondicionado (evaporador, compresor y condensador, incluyendo la válvula del presostato) le probé incluso otra BSI y otra ECU de motor y aún sigue fallando.
Google Translate
Greetings friends, I have a Peugeot 2008 year 2020 that has a problem with the air conditioning, when you turn it on it cools, then the pressures rise and the compressor turns off, it gives me the code B132F 81, the entire air conditioning system has already been changed (evaporator, compressor and condenser, including the pressure switch valve) I even tried another BSI and another engine ECU and it still fails.
Reason: Translation added.
x 6945
Re: B132F 81
Asegúrese de que todas sus publicaciones estén escritas en INGLÉS, ya que este es un foro en inglés. Utilice una utilidad de traducción como Google Translate si el inglés no es su primer idioma.
Please ensure all your posts are in made ENGLISH as this is an English language Forum. Use a Translation utility like Google Translate if English is not your first language.
Fault Code: B132F 81
Description of Fault: _air conditioning high pressure information invalid. High pressure value invalid. Conditions of activation of the diagnostics: Main triggering of the intersystems CAN.
Conditions for Fault to clear: Valid high pressure value
Downgrade Modes whilst Fault is active:
  • Air conditioning pressure invalid
  • Compressor declutched
  • Displacement valve closed
Symptoms:
  • Malfunctioning of the production of cold air
  • Malfunctioning of regulation of the temperature requested
  • Malfunction of the windscreen demisting/de-icing
Suspect Areas:
  • Air conditioning pressure sensor
  • Electrical harnesses
