Hi got problem with peugeot 2008 , first is urea mean ad blue system
Problem is approx 1 month all lights on urea light Engine, Dpf fault on dash
Ad blue topped up pats fluid topped up both systems counter reset all lights off
After 4 weeks urea light on warning on dash engine shut down in 50 mls
Fault codes = P0A2 de nox system circuit
P0E8 pressure of urea fluid
P069 pressure of urea fluid
I think it could be AD blue pump or something, could you help with wirng diagram for ad blue system so I can check pump is powered ect
VIN, VF3**************[VIN obfuscated, can be read by forum staff]
Also where is ad blue injector fitted can system be tested with diag box , pump injector
Thanks Joe
PEUGEOT 2016 2008 ADBLUE ?
- x 6954
Re: PEUGEOT 2016 2008 ADBLUE ?
Your missing some parts of the code, so can't assist there and don't have a diagram for this vehicle.
With pressure faults it could be anywhere from the pump in the tank to the heated UREA pipe, to the UREA injector. But whatever it is your time is limited as it won't start as you know in 50 miles and you don't want to get stranded. You may want to cut your losses and get it dealer checked given the circumstances and time constraints.
