water in 508 eat6 gearbox :(
kabadayitalat
Unread post by kabadayitalat »
hi
i have a 2016 bluehdi 508
I had a problem with my gearbox last week. I started having problems shifting gears.
When I checked the engine , I saw that the water container was full of oil. this was atf oil. :cry:
My mechanic said the transmission oil cooler was punctured.
When we removed the oil cooler, we saw that water had mixed into the transmission.
I bought 12 lt motul atf6 and we changed it to 3 turns 4/4/4.
I will use the car for 200 km and then we will change it 2 more times (4/4) with 8 lt motul atf6.
Do you have any other advice for me in this situation? What else can I do?
x 1490
Re: water in 508 eat6 gearbox :(
If you've got water in the transmission, it's life is likely to be severely shortened. If it works, keep driving, but be ready to replace it at some point.
x 1995
Unread post by Stickyfinger »
Depends.....
IF you have caught it early (that is a guess) then maybe 2 or 3 full changes of oil using a power flush machine -might- flush it fully...........the cost of that is still below replacing a gearbox.
kabadayitalat
eat6 is working fine now and seems to have no problems. But I know there is some water left in it. I didn't use it like this for a long time. approximately 300 km. When I started having problems with the gears, I checked it. Then we changed the parts and oil. If I find a place that will wash the transmission completely, I will have it done. I understand water can cause big problems.
I used motul atf6. I think this is the right oil. The seller confirmed this. We may have overfilled the eat6 oil level a bit. I think this will not cause any problems.
