No.12 10A fuse keeps blowing, speedo, temp gauge.
puggydt
Unread post by puggydt »
Reversing lights, coolant level sensor etc all controlled by this fuse.Sometimes it blows when ignition is first switched on,or as soon as the engine fires up.Also coolant temp led on faintly + ECU stop lamp also on faintly [:(!]
Any ideas [?]
Cheers
puggydt
OOps ![:I] the car is a 306Dt 1996.
Cheers.
puggydt
Anybody ?
kevin
Unread post by kevin »
Out of curiosity, is the car in reverse gear, i.e. the reversing lights are working, when the fuse blow's?. If so there is a fault on this circuit. On my 306 the PCB for the rear combination lights are corroded and are occasionaly troublesome.
Also are any other electric devices working or phone chargers plugged in as these can also blow fuses and relays.
Kevin
