Recall codes
Nhokas
Recall codes
Unread post by Nhokas »
How can i know what is “changed” on the following recall codes:
HZR
JFU
JHW
JQF
Thank you
x 6955
Re: Recall codes
These are the only recall codes applicable to your vehicle that are outstanding:
JHW:
C5 Aircross PHEV - Traction Battery, Lower Support
Add drain holes to lower traction battery support (If not already present). Dry area between support and lower traction battery casing with air pressure. Apply corrosion protection wax to create a barrier against corrosion.
JQF:
C5 Aircross - BMS software
BMS (Battery Management System) will be reflashed with an enhanced battery monitoring software. In case defective High voltage battery will be detected, High voltage battery will be replaced.
Nhokas
Re: Recall codes
According to DS the first 2 where already done... Just wanted to know what was (HZR and JFU)
Nhokas
Re: Recall codes
No?
x 6955
Re: Recall codes
I can't tell you because once the after-sales campaign has been completed, they are removed, so I can't advise of what they are for. Only those outstanding are displayed.
Contact your dealer and they may tell you, but they don't like to provide details of these generally.
