Transmission oil of Aisin
Joenmark
Unread post by Joenmark »
The car C5 aircross, model 2021, has an Aisin automatic transmission. What quality requirements does the oil have to meet? The price of oil in brand maintenance is around €100/litre. The transmission has the following markings:
982223488
9830761080
617204A102882
x 6950
Re: Transmission oil of Aisin
That indicates you have the AMN8 gearbox, which requires AW2 oil, and yes it is expensive, but has specific properties required for this 8 - speed transmission.
Quote from SAE International
Author(s): Kohei Masuda, Hajime Nakao, Hitoshi Komatsubara, Osamu Kurosawa, Katsuhito Yamada, Kazunori Ishikawa, Atsushi Mori
Affiliated: JXTG Nippon Oil & Energy Corp., Aisin AW Co.,Ltd.
Super Low Viscosity ATF; AW-2 2018-01-1756
Reducing loss torque in automatic transmissions (ATs) is a key factor in improving fuel economy. A promising approach is to reduce the viscosity of the Automatic Transmission Fluid (ATF) so as to minimize churning loss. Aisin AW and JXTG Nippon Oil & Energy Corporation have developed a super low viscosity ATF, called “AW-2”, which has approximately 50% lower kinematic viscosity at 40 °C compared to the conventional ATF “AW-1”.
It is generally understood that if the viscosity of an ATF is too low, it can have a negative impact on the fatigue life of components such as gears and bearings, and possibly lead to increased wear or seizure. AW-2 was designed to solve these problems via the application of two key technologies. The first is a high performance base oil with a low traction coefficient, which translates to low viscosity under high pressure conditions. This decreases the shear resistance between sliding surfaces under elastohydrodynamic lubrication (EHL) conditions, which contributes in improving the fatigue life of bearings and other components.
The second is an ester type base oil with high polarity. It was found that the amount of ester base oil used has a major influence on fatigue life. The adsorption of esters onto metal surfaces is thought to improve lubricity in severe lubrication conditions. Durability tests were performed in a wide range of conditions, using gear and bearing components and actual transmission units, and it was confirmed that AW-2 outperforms AW-1, despite its super low viscosity. Furthermore, AW-2 reduced loss torque in the transmission by approximately 10% compared to AW-1.
citroenguy
(Donor 2021)
x 77
Unread post by citroenguy »
Hi
In Sweden you can get this AW-2 grade ATF for around 26€ a litre
https://www.mpmoil.se/products/16000ULV ... -fluid-ulv
Surely you gan get it over the border?
I have various repair handbooks and wiring diagrams for C5 mk1, Xantia, XM, Berlingo and C3 mk1.
I have Lexia/Diagbox (Sweden) and Servicebox/sedre
Joenmark
GiveMeABreak wrote: 19 Oct 2023, 09:53 That indicates you have the AMN8 gearbox, which requires AW2 oil, and yes it is expensive, but has specific properties required for this 8 - speed transmission.
Is this the right oil for this transmission? Does anyone know if this is approved by the gear manufacturer?
https://www.ravenol.de/en/product/getri ... -ulv-fluid
x 6950
Yes, that will do fine :wink:
