Hydraulic Pipe renewal
meteor
Unread post by meteor »
Hi
Xantia LX 1.8 1995.Metal Hydraulic pipe near front drivers side sphere is leaking fluid from what appears to be a microscopic hole in the pipe. Is the pipe easy to repair?? If so does anyone know the part number of the replacement pipe and required associated nuts and seals etc.?
Would appreciate any help with this.
Jon
Unread post by Jon »
The RH metal hydraulic pipe seems to be a bit of a problem on Xantias.
The Citroen reference for this part is 5270EC, and the GSF reference is N65967.
The pipe requires a standard 3.5mm LHM seal at each end.
I have not had the "pleasure" of fitting one as yet.
Jon Wood
IT Supervisor
GSF t/as Andyspares
