When the ECU touches the positive lead
justinzak
Unread post by justinzak »
Just making a small post for anyone who does this by accident.
I see this happen often in Peugeot partners/berlingos and similar
The ECU gets moved, or the fuse box is pulled to access lower fuses. The ECU security casing can incidentally touch the fuse box battery lead, or a stray battery fuse board.
The ECU itself is earthed through a few earth wires, and the current will travel through these.
What will happen, is the pins will generally resolder themselves since there is zero resistance. After this, the ECU will not communicate. A quick dab with the soldering iron and it's good to go.
If the ignition was on when the ecu was shorted, you're in for a world of pain.
Huskyxantia
x 904
Re: When the ECU touches the positive lead
Unread post by Huskyxantia »
Great post . Thanks for sharing this is well worth knowing.
:-D
Stillstunner
Unread post by Stillstunner »
I just literally done this and think I’ve fried my Ecu ffs
