Quartz 9000 Oil
volcane305
Quartz 9000 Oil
Unread post by volcane305 »
Where can I get a cheap supply of the above oil. I plan to change every 7-8k miles in my xsara 110 hdi due to entusiastic driving style so want to get a supply that will last a year or two (4 changes per year). Based in N.Ireland.
alan s
RIP 2010
x 6
Unread post by alan s »
I'm not going to volunteer to send you a supply, living where I do[:D] but from experience I've found if you contact your local distributor and tell them you want to but it in 20 litre lots (a carton of 4 X 5 litre bottles) they'll usually talk a good deal.
Alan S[8D]
reffro
Unread post by reffro »
I bought 20 litres not long ago from a supplier, though for the life of me I can't remember who and where, as it was couriered to me. The cost was £59inc. delivery so I'll look for the name of the place for you when I get home.
OK, I tracked them down. Unfortunately the oil when I bought it was a special price, they now want £94inc. delivery for 20 litres. You can now buy oil again from GSF online, and they are selling it at £17.04/5litres plus delivery. So if you order your two years supply in one go, it will work out cheaper to get it from GSF, assuming they deliver to N.Ireland.
volcane305
Thanks Reffro, I also recall seeing somewhere at £59 but thought it would be easy enough to get it at that price when I needed it. Alans maybe I could collect from you?????!!!! but would be expensive oil and She might not take that as a valid reason for heading down under!!!!
alan s
RIP 2010
x 6
To give you some idea of the possible price differences, I was told that a certain Elf synth was $23 a litre in Sydney from a car accessories shop.
I can buy it for $10 from the distributor, so it's worth having.
Alan S
DoubleChevron
Unread post by DoubleChevron »
I just go to the local Big 'W' store out here. They have Shell Helix in 5litre containers 15-50 semi-synthetic (which I thinks a pretty reasonable sort of oil for most motors) for about $25.00 (or 10pounds).
I've never found cheaper oil with a decent rating than there (eg: 20-40 mineral oil is always cheap, but unless it's a bog stander CX or DS, why would you use such a thick oil ??).
seeya,
Shane L.
Kowalski
Unread post by Kowalski »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by DoubleChevron</i>
seeya,
Shane L.
20-40 is actually thinner than 15-50 at engine operating temperatures.
The 15 or 20 is the low temperature viscosity where as the 40 or 50 is the high temperature viscosity.
DoubleChevron
Yep,
that's right, however startup time the most important when it comes to how thick oil is [:p] I like 'em thick when the motor is hot, and thin when the motor is cold.
seeya,
Shane L.
ohms69
Unread post by ohms69 »
I have a contact for quartz 9000.
I get it for £55 for 25 litres. I collect but the guy can ship.
[8D]
