Help - XM Warning Lights
Assich
Unread post by Assich »
I've never seen these together before, the exclamation and the brake lights warning lamps on together for a few seconds then go out. Occasionally accompanied by the large STOP warning light. Seems to be randomly but generally occasionally under hard acceleration from low speed or turning a corner. LHM, oil and coolant levels all good. I have tried disconnecting the LHM and coolant level sensors one at a time with no change. Same with oil pressure. Suspension, steering and brakes appear fine pressure wise.
1992 2.0i 8v Citroen XM Prestige Auto
2006 3.0i Citroen C5 Exclusive Auto
x 1460
Re: Help - XM Warning Lights
Unread post by xantia_v6 »
Front brake pad wear sensor?
Assich
Unfortunately like many xm's the wiring harness is no longer there so unlikely but I'll check. I' m thinking I can connect what's left on the body connector and see if I get the same warning lights. Thanks.
