Problem with the driver's door lock, the car does not detect whether the door is open or not.
I got error B173A 00
The lock has already been replaced because the previous one did not lock the door
Peuegot 508 problem with drivers door
- x 1055
Re: Peuegot 508 problem with drivers door
Check for broken wires in the harness that goes between the door & body by the hinges. As the wires are constantly flexing this can be a common weak point on most cars.
cuddlezuk
Did you get the drivers door fault fixed? If so what was it as my car has same fault on a 308 1.5 diesel 2019.
