Hello everyone.
Im new here and just seeing if I can locate a workshop manual for my 2007 Citroen C3 as I am needing to replace the cambelt and water pump very soon as its overdue. If anyone has or knows where i can get a copy of a manual from that would be much apprieciated.
Thankyou
Jack
Workshop manual
- x 6950
Re: Workshop manual
Apart from older paper-based ones on ebay, you'll probably be better off with the later digital versions from Haynes - so you won't have issues of postage to NZ. You can usually opt for a PDF version or the live version which is viewed online as you need it (and is therefore updated where the PDF versions are not).
https://haynes.com/en-gb/
