Miffed at my MAF!
numnuts
Miffed at my MAF!
Hello all. I have a 2005 Berlingo Multispace, 1.6 petrol. It has just started to stutter and stall, mostly when accelerating in first gear, but affecting all gears. Whenever I rev, it seems to want to stall. It gets really juddery when idling. The engine warning light has come on too. I previously had a 2litre HDI Berlingo and had exactly the same issues, which turned out to be down to a knackered MAF sensor. Based on the issues I'm having with my petrol model, could it be the Maf sensor? I would really appreciate any advice. Thanks. Tony.
- x 1083
Re: Miffed at my MAF!
Best way to check is to unplug it, it's as simple as that
Champion of Where's CitroJim
- x 6950
It needs a diagnostic. This sort of behaviour is common to a air / fuelling fault, but you don't want to be replacing parts without a diagnostic being done. If you can get that done then pop the fault codes up here we may be able to give some pointers.
numnuts
Thanks for the suggestions guys. Much appreciated
