DS5 2012 2.0l Hdi 165 RHH coolant change
Cagey
Unread post by Cagey »
Hello!
I have been looking to change my coolant before winter as I can see its quite dirty in the reservoir tank. My car is a 2012 DS5 Hdi 165 RHH engine and auto transmission. I cant seem to locate any bleeder screws or valves in the engine bay. I really love the car and want to take care of it. Does anyone here have some pictures, video/procedure on how its done?
Thanks in advance
Ivan
x 6947
Re: DS5 2012 2.0l Hdi 165 RHH coolant change
Follow the procedure here in the resources section - it's the same:
viewtopic.php?t=64036
Cagey
That was a quick reply. Thank you so much :)
PaulC5
x 698
Unread post by PaulC5 »
Just a comment, your car is 11 years old so should have had the timing belt replaced by now based on age if it has not already been done based on distance. The water pump is usually changed at the same time so the coolant would have been done with the belt. If the belt has not been done then beware it can be at high risk of failing.
Cagey
Thanks for the comment Paul. Thats really good advice since my timing belt and water pump was done november last year. Still its quite dirty in the reservoir tank so I'm thinking of changing it.
