Hi
Whilst freeing off the adjusters for the rear toe adjustment (not a nice job) I noticed that the handbrake cable is chaffing badly on both sides at the same points, namely the top of the stub axle and then on the rear subframe mount. Are there some brackets that hold the handbrake cable in position? Its very poorly designed if not!!!
Any help would be appreciated..
Dan
