DS5 Auto 1.6 13 reg
Citroenmonamor
DS5 Auto 1.6 13 reg
Unread post by Citroenmonamor »
I purchased a used D5 1.6 Auto 13 reg with some gearbox fault in an auction. The gearbox error code showed up.The previous owner i purchased it off had said it was an occasional problem. I got the car trailered home just in case of trouble..When the car finally arrived it would drive around in low gear before displaying the gearbox problem and refusing to engage gears and staying in neutral and also not staring. On checking tne battery it had average charge even after an off car charge..I got a new battery fitted and the car worked fine engaging gears properly . I also cleaned up the above battery fuse box and checked all fuses for resistance.The fuses were all fine but the battery positive lead had one connection lead that had poor continuity, so I cleaned it up which improved that..i drove it for an MOT today and it passed 1st time. I then drove it around town without fault. I then took it on the Motorway and put it in manual instead of auto then tne esr fault came on then the abs,then the gearbox error .The car continued driving ok although in manual it would changed gear like an auto. I stopped at the services for 10 mins started up again with no faults showing. I drove it back home, at under 40 mph it drove fine but over I needed the manual paddle-shift to change down it also wouldn't go above 3rd gear. Again thinking this is an electrical fault possibly with back continuity in the above battery fuse box..Any ideas on this appreciated
x 6963
Re: DS5 Auto 1.6 13 reg
You need it properly diagnosed, preferably using a Lexia kit with Diagbox. There is a substantial list of potential fault codes for these boxes, so impossible to provide you with an answer without these.
When you have them, pop them up with your VIN for further help.
Citroenmonamor
Codes are P1755, U2000, U1213, U0415..Vin number is VF7**************[VIN obfuscated, can be read by forum staff]
x 6963
Please note I've deleted your other topic regarding the fault codes as this causes duplication of answers when you've asked about them here. :wink:
Ok, so Fault P1755 can arise from contamination in the gear control piloting actuator. The recommendation on other vehicles is to try the gearbox programming procedure. If it fails, the recommendation is to replace the clutch stop. If it is successful, then the recommendation is to replace the piloting actuator.
So this is really a dealer job to ascertain the correct course of action.
To say these boxes are a pig when they go wrong is an understatement, but here are the descriptors for you:
Fault Code: P1755
Description of Fault: Clutch jammed: Coherence. Clutch actuator fault: incorrect position in relation to the reference value.
Context of appearance of the fault code
At least one of the following conditions must be fulfilled:
- Free wheel
- engine running
Technical precision on the context of appearance of the fault code:
- In gear changing phase
- In clutch opening phase
- Absence of error on the clutch electrovalve and on the engine speed signal
Conditions for Fault to clear: After switching the ignition off and then back on
Downgrade Modes whilst Fault is active: If there is a problem with opening the clutch:
- Automatic mode deactivated
- Change of gear interrupted
If there is random closing of the clutch:
- Emergency selection of neutral
- Change of gear prohibited as long as neutral is not engaged
If there is a problem operating the clutch:
- Emergency request for stopping of engine provided engine close to idling speed
- Gear change deactivated
If the clutch is jammed open:
Opening of the clutch
If there is a problem with initialisation of the closed position:
No back-up mode
If the vehicle has the Stop and Start system: Stop and start function deactivated.
If there is random closing of the clutch during the Stop and Start phase: Restarting in Stop and Start mode impossible.
Switching on of the warning lamp and/or warning message (*):
"SERVICE" warning lamp
Sport warning lamp
Snow warning lamp
Automatic or 6-speed piloted manual gearbox warning lamps (Orange PRND triangle)
Display of a "-" on the fascia panel
Symptoms:
  • Lack of power
  • Impossible to make the vehicle move
  • Absence of automatic stopping of the internal combustion engine
  • Problem with automatic restarting of the internal combustion engine
  • Leaks
Suspect Areas:
  • Clutch position sensor
  • Pressure sensor
  • Electrovalves
  • Gearbox ECU
  • Electropump
  • Electrical harness
  • Clutch
  • Level of oil in the gearbox reservoir
  • Clutch release bearing
  • Leak on the clutch control
  • Pump
Fault Code: U2000
Description of Fault: Main wake-up request information reception fault: Not characterised. Main wake-up signal absent or invalid.
The time of appearance of the fault code is 1s
Context of appearance of the fault code:
- During the main wake-up phase
  • No faults for 1 second
Downgrade Modes whilst Fault is active: -
Symptoms:
  • Difficult/impossible to change a gear
  • Lack of power
Suspect Areas:
  • 28-way connector of the piloted manual gearbox ECU
  • 28-way harness of the piloted manual gearbox ECU
  • Built-in systems interface
Fault Code: U1213
Description of Fault: Fault with the information sent by either the ABS/ESP ECU or the electric parking brake ECU: Value received incorrect. Absence, or wrong value, for the CAN information containing the electric handbrake status, the torque requested by the ESP ECU, or the rear wheel speeds.
- Ignition on
- Technical precision on the context of appearance of the fault code Supply voltage correct
- Absence of fault codes U1000 - U1003 - U1113
- The system is not in starting phase
Conditions for Fault to clear: Reception of 20 consecutive items of valid information
Downgrade Modes whilst Fault is active: Possibility 1
Electric parking brake: Invalid signal
- Engine running or in Stop and Start phase; Replacement value: Brake activated
- Engine stopped and not in Stop and Start phase; Replacement value: Brake deactivated
- Crawling deactivated
Possibility 2
- Signal for the torque requested by the ESP ECU: Prohibited value
- Replacement value: 0
Possibility 3
Signal for the rear RH/rear LH wheel speeds: Invalid signal
- Calculation of the replacement value from the vehicle speed
Symptoms:
  • Lack of power
Suspect Areas:
  • Gearbox ECU
  • ABS/ESP ECU
  • Electric parking brake
  • Controlled manual gearbox ECU
Fault Code: U0415
Description of Fault: Fault with the information sent by either the ABS/ESP ECU or the electric parking brake ECU: Value received incorrect. The average front wheel speed information on the CAN is incorrect.
- Ignition on
- Supply voltage correct between 8V and 16V (Pin 3 of the 28-way connector)
- No communication fault on the CAN
Conditions for Fault to clear: Reception of 20 consecutive items of valid information.
Downgrade Modes whilst Fault is active: The gears above 3rd gear cannot be engaged.
Change of gear impossible in the presence of additional faults (Input shaft speed; Engine speed; Gearbox input speed; Accelerator pedal position)
Symptoms:
  • Lack of power
Suspect Areas:
  • Gearbox ECU
  • ABS/ESP ECU
Citroenmonamor
HI, I have had the clutch, flywheel, Clutch Position sensor changed what is the procedure next on the Diagbox ??
Citroenmonamor
As it not engaging anything
x 6963
You have a piloted manual system, so It won't work until you have had the clutch and gear actuators programmed. This is a procedure contained within Diagbox.
Citroenmonamor
Silly question but do you have to get the clutch bitting point 1st or is it straight into the clutch actuator programming then the gear actuator programming ?
Citroenmonamor
Update..A garage changed the Clutch, Flywheel but we had a problem getting it to change change gear ..I had them fit a used ecu for the transmission..Their auto electrician has used his Autel machine to program the gearbox and remove faults codes. its going in gear from their Autel, but its still giving the Error Code P1800 and not going in gear from the car gear lever..Any ideas please??
x 6963
Doesn't look like their tool is capable of doing the job properly, especially as this is a new fault code after they have attempted to programme it.....
Fault Code: P1800
Description of Fault: Gearbox programming incomplete or not carried out fault: Not characterised. Selection gate initialisation not completed or not done.
The following conditions have to be met:
- ECU woken up
- Ignition on for more than 5 seconds
Conditions for Fault to clear: -
  • Automatic mode deactivated
  • Crawling deactivated
  • Take-off deactivated
  • Gear change prohibited
  • Switching on of the warning lamp and/or warning message (*): "SERVICE" warning lamp
  • Sport warning lamp
  • Snow warning lamp
  • Automatic or 6-speed piloted manual gearbox warning lamps (Orange PRND triangle)
  • Display of a "-" on the fascia panel
Symptoms:
  • Lack of power
Suspect Areas:
  • Programming to be carried out in after sales
Citroenmonamor
Well they said the car went though the phase changing gear etc but was stuck on the p1800 Code..
Citroenmonamor
I got a used ecu and they fitted it, was any other ECU programming needed doing to make it work .Do they need any codes for the immobiliser??
Citroenmonamor
Or cloning it to the old ??
x 6963
If you're talking about the piloted gearbox ECU, no you can't clone this - it has to be properly programmed as per the following operations which have to be done if the ECU is replaced:
  • Pressurise and bleed the hydraulic circuit
  • The initialisation of the clutch engaging point
  • The initialisation of the gearbox grid
  • The writing of the counters into the new gearbox ECU
  • Programme the value of the engine torque transmitted to the clutch using the diagnostic tool.
Citroenmonamor
There was 2 reversed wires on the actuator, the auto electrician fixed it.
