Hi all,
Just wondering if there's a guide available for replacing the caliper on a 2009 c5 estate? (Manual handbrake, not electric).
One side has seized up, so I'm assuming it needs to be replaced.
Thanks!
c5 x7 - rear caliper replacement?
- x 8172
Re: c5 x7 - rear caliper replacement?
Don't jump into replacing it immediately without checking it out properly. You can get refurb kits and rebuild it yourself, ensuring a clean environment at all times, as long as you can dismantle it:
https://www.ebay.co.uk/itm/283003134269 ... R6SYspXaYg
- x 1083
It's probably the gromit leading into the brake caliper, don't buy a whole set without checking first!
Champion of Where's CitroJim
Agour
- (Donor 2026)
- x 8
ahh I didn't know you could do that! Are they difficult to refurbish? Tried looking online but cant find any info
- x 6950
I've answered your calliper replacement part request on the parts thread, but you will see from the parts diagram that certain parts of the calliper are also available, so respond to that post if you need additional part numbers for any of those, but any technical questions, please keep those here on this thread, thanks.
