BSI Reset, Peugeot Expert. I've read the Sticky post by Marc, but my battery is in the footwell, driver side.
I'm trying to diagnose a rear door (Tailgate) locking issue. I think it's mechanical problem, but I can't figure it out so wondering if a BSI reset might cure it?
Any idea how to do it when the battery is inside the cabin?
thanks.
BSI Reset-2015/16 Peugeot Expert...Battery in driver footwell.
ImNoExpert
- x 6945
Re: BSI Reset-2015/16 Peugeot Expert...Battery in driver footwell.
In that case, you will need to fool the BSI into thinking the door is closed, so flip the door lock with a screwdriver if possible to the locked position so you can keep the door open whilst you disconnect the battery.
ImNoExpert
ah i see. Thanks again Marc.
Could a door locking issue be BSI related? I don't want to fix it if it's not broken (the BSI i mean)
- x 6945
My advice is to have it properly diagnosed before doing anything if the BSI reset doesn't work. The fault codes will help pinpoint the issue.
ImNoExpert
I have Diagbox 9....but it's not showing a fault with the doors....Safe to assume it's Not BS related then i guess.
Cheers
Cheers
- x 6945
Do a Global test and then report any errors returned if any.
