Basically when starting cold it gives a bit of white smoke from the exhaust (2-3 seconds tops) that doesn’t smell too nice
I tried checking the resistance of glow plugs in order to see if they work, they all are approx. 1.9-2.1 Ohms each. Could this be the g.p. relay? Should I be more concerned about the state of injectors? I had a Toyota avensis a while back and the faulty injectors were obvious - it ran like a tractor and smoked bad.
The other thing that interests me is there is no glow plug light on the dashboard. If I’m not mistaken it should come up every time I turn the ignition on, even for a split second (if it’s warm) and then go off - nothing like this happens.
Of course I plugged in my elm327 interface, but no trouble codes come up - no faults detected.
