407 2.0 HDI RHR Autotrans, No crank:P1828
pesoo
Unread post by pesoo »
tried to search forum but no success for P1828 :(
No crank was intermittent few months until last week no crank at all, repair shop had replaced starter when this issue started..
Today i read faultcodes and there is P1828 Starting prevention signal(start lock) short circuit to positive- code Permanent.
On instumeter cluster is only Dash on Gear position and a triangle with PRND.
i have found one conversation where is said that there is wiring fault, it would be good help to have wiring diagram before i start to stip down while wiring loom :)
Didnt had time today look it so i havent look wiring loom shape.
Vin: VF3**************[VIN obfuscated, can be read by forum staff]
pesoo
Re: 407 2.0 HDI RHR Autotrans, No crank:P1828
Any ideas to this issue? :?:
pesoo
fault was in wiring, from gear swichsensor connector to TCM
x 3296
Well done in tracking the fault down, and thanks for your explanation.
