Can you pls. Put up the alternator changing procedure manual?
Thank you
Alternator replacement
508c5
- x 4
Re: Alternator replacement
Can you also indicate where the alternator fuse is located? No indication in the owner's manual
- x 6945
Link Here:
508 Alternator Removal & Refitting
There is no 'fuse' for the alternator, it is connected directly to the battery.
508c5
- x 4
Thx
I actually run a as search before posting but didn't find anything, i see now its on the members zone , i didn't look there
- x 1460
If you look at the date on that guide, you may see that it wasn't there until you asked.
508c5
- x 4
xantia_v6 wrote: 17 Sep 2023, 20:46 If you look at the date on that guide, you may see that it wasn't there until you asked.![]()
didn't notice
