it still wont start
kangoo michael
it still wont start
Unread post by kangoo michael »
Thanks for all your previous replies but it still wont start.
2001 kangoo D55 with 1.9 DTI engine lucas epic pump.
new fuel filter.
all relays checked and fuses next to battery
all wiring checked for damage, terminals all clean .
current flow checked with noid tester
stripped pump so i could see the stop plunger moving
bled fuel lines dozens of times so no air
new crank sensor fitted
just about to check pump timing
when given a squirt of easy start its reluctant to start it just chug a bit
on my cheap obd tester the only fault code is low transmission fluid
the alarm light works as it should
also new glow plugs and injectors checked by specialist
Any help to point me in the right direction i will be thankful.
